94 lt1 to ls1 swap?
94 lt1 to ls1 swap?
hey guys, my friend recked his 99 camaro hes going to part it out. im thinking about getting the motor, does anyone have a link to a motor swap like this or what all need to be changed to be done? anyhelp would be great!
If you only want to get rid of the opti then get his coilpacks, wires, wiring harness, and PCM and do the LS1 PCM conversion. You will have to buy a 24x reluctor wheel as well. Much easier than swapping the motor.
theres the brakes if one has traction control and the other doesnt you would need the rearend as well. you will need the body control modual so the under dash harness and whatever is defferent there. your right with a obd2 lt1 it would save alot but in the case of a 94 it would take alot. the easiest and least expensive way to almost get rid of the opti is going with ltcc or more money efi or fast
http://www.bailey-eng.com/LTCC.html
right i said almost get rid of it. with all of them you need a crank/cam sensor. one of the fast setups uses the the opti as well but for spark and requires a crank sensor. the efi requires its own 24x crank sensor.
9434V6
09-08-2011 11:51 AM
