LT1/LT4 Tech 1993-1997
94 LT1 into 96Z
Old Jul 1, 2012 | 01:29 PM
Otter72's Avatar
i might be better puttin a trans in the 94 and looking for a 96 eng! thanks for the knowledge!
Old Jul 1, 2012 | 10:41 PM
Originally Posted by craby
i think it will work but you will have a ses light all the time and will run in open loop all the time which will cause it to run rich. you can get away without changing cam by drilling out the center hole in the cam so the new style opti will fit, otherwise you will need a different cam, (you may want to do chain) cam gear, front cover with crank sensor, seals and gaskets for front cover, new style opti, crank sensor,
Why does he need to install a new style opti. You can add a vent kit to the old style, if that's the reasoning.
Old Jul 2, 2012 | 12:36 AM
yah i tend to blend things together to much. in order to do it so the ses light is not on and the computer to work right he will need to change those things.
Old Jul 2, 2012 | 12:53 AM
A piece of tape over the light would be a whole lot easier! lol
Old Jul 2, 2012 | 12:59 AM
come to think of it the pcm could be tuned to let it go into closed loop, it would lose at least some of its ability to diagnose without the crank sensor
Old Jul 2, 2012 | 01:08 AM
Right, that's why I was asking why you'd go through all that trouble of converting it to a new style opti. He would then have the equivalent of a 94, but in 96 clothing.
Old Jul 9, 2012 | 08:45 AM
frankzlt1's Avatar
He can get a tune to make that engine work in a 96. But depending on where he lives and the state emissions requirements he can do a obd1 convert. Mad z28 does that and if your state doesn't have any emissions with that car you can barder your obd2 with the tuner for a the obd1.
