94 engine harness swap into 93 z28
Hi can anyone help with putting a 1994 engine harness into 1993 lt1?The plug looks the same but are all the wires in the hook up the same? Can I just plugthe 1994 engine harness into the 1993 power harness? Thanks
RE: 94 engine harness swap into 93 z28
It should work fine, just use all the wiring from the 93 car, especially the injector wiring, as the 93 computer batch fires the injectors while the 94 sequentially fires them.
