LT1/LT4 Tech 1993-1997
93 z28 water pump problem
Old Jun 5, 2006 | 09:02 PM
Saint_Ali's Avatar
Default 93 z28 water pump problem
Hi i have a 93 z28, i have owned it for about 6 months now.I just replaced the water pump with a new one because the previous one is leaking and now the new one is leaking and was installed about 2 months ago.Has anyone else had this problem ? any suggestions ?
Old Jun 5, 2006 | 09:26 PM
SickSickSick's Avatar
Default RE: 93 z28 water pump problem
Is it leaking from the weep hole? Sick
Old Jun 5, 2006 | 11:00 PM
Saint_Ali's Avatar
no i dont think so, it looks like its leaking from the front
Old Jun 6, 2006 | 12:42 AM
The only thing i know that wears water pumps out at an advanced rate is running them with too little water. on older style v belt pulleys you can wear one out quickly by running your belts too tight but, yours has a serpentine belt i would imagine and it's less likely your belt is too tight. sorry i could'nt help you more. maybe you just have bad luck 8-) . Sick
Old Jun 6, 2006 | 02:14 AM
The only things I can think of are: the front cover of the pump could be loose, the pump is otherwise defective, or it was installed improperly.The LT1 pump is gear driven so there should not be any undue wear on the pump bearings or seals. As Sick mentioned, running the pump low on water can damage it. The other problem you going to have is that when the pump leaks, the Optispark gets wet. and when the Opti gets wet, it soon dies.
Old Jun 8, 2006 | 02:30 PM
pdpallen's Avatar
Learned exactly what pete said the hard way, my water pump leaked now my car is on stands getting the opti replaced. And those things are outragesly expensive.
Dealership want $675 for new one
Found a remaned opti with lifetime warranty at O'Reilly Auto Part for $150. Does not include cap and rotor, but does include control module.
Old Jun 8, 2006 | 03:13 PM
97FIRECHICKEN's Avatar
another thing that can prematurely cause a h20 pump to die on lt1's is not running dex-cool and using other kinds of coolants. the dex-cool actually has silicone in it which is critical to maintaining our cooling systems
Old Jun 8, 2006 | 05:40 PM
Saint_Ali's Avatar
ok thanks i didnt know that about the dex cool, that really helps me out
Old Jun 18, 2006 | 09:23 PM
Saint_Ali's Avatar
well i took the old water pump off today and found out that one of the reason it might have leaked is because i took it to meineke to get the work done on it and they didnt put any gaskets on the water pump
doww301
Apr 4, 2011 02:49 PM
JordanN
Aug 10, 2010 07:37 PM
1995z28AJ
Jul 27, 2007 04:10 PM
1995z28AJ
Jul 22, 2007 11:40 PM
coolcarjr
Sep 18, 2005 07:37 PM
