LT1/LT4 Tech 1993-1997
93 Z28 HP
Old Jul 23, 2007 | 07:15 PM
3RDGENZ28TX's Avatar
Default 93 Z28 HP
I GOT A 1993 Z28 WITH A LS1 AND 54CC CORVETTE TARGET HEADS AND A 342 POSI BEHIND A 6 SPEED HOW MUCH HP DO I MAKE thanks for the help and sorry about all caps
Old Jul 23, 2007 | 10:07 PM
nickdotcom's Avatar
Default RE: 93 Z28 HP
did you swap the LS1 into it? 93 is an LT1
what are corvette "target heads"? stock vette heads are the same as the LS1 thats already in there, unless its z06...
Old Jul 24, 2007 | 04:30 AM
TheStig's Avatar
ORIGINAL: nickdotcom
yea, if you do have an LS1 in there it would have had to been swapped in. And the entire engine, both LT1 & LS1, is a corvette engine.
Old Jul 24, 2007 | 08:59 PM
my bad i ment lt1 and those are the heads that the previous owner said were on it i dont no much about 4th gen camaros and fuel injection but i just thing they were pulled off of a corvette so what should i be pushing from the stock setup it only has 43000 miles its fairly new thanks
Old Jul 24, 2007 | 11:55 PM
95slvrZ28's Avatar
The stock heads are Corvette heads. So unless the previous owner was a moron and replaced his aluminum LT1 heads with aluminum LT1 heads, it sounds like he tried to make it a selling point. Nonetheless, stock HP is 275 for a '93.
