93 motor into a 95 camaro
take all the sensors from the 95 if there are any questions. alot of them are the same. go online to a parts place and see which are for a 93 only if there are any. i think the only reason the opti is different because the 95 is vented. the 95 has a maf the 93 has a map so u will need to stay with the 95 maf and the 95 ecm/engine control mod. check to see if the air intake temp sensor is different and in a different location, if so the intake will need to be from the 95.
