93 Camaro Z28 5.7L LT1 Water Pump Repair Instruction
Hello Friends!
I was wondering if anyone out there would have instructions/diagrams on how to replace my 1993 Camaro Z28 5.7L LT1 Water Pump?
Any help you could give me would sure be appreciated, I am trying to save a few buck by doing it myself, but I have never replaced one of these before. I have a new pump and the gaskets but need a little advise/repair info. If you have any docs that would be great!
Thanks so much friends!
see if u can read this. from my 93 camaro dealer service manual. u will also need to take the serpentine belt off. would be a good time to check out the plug wires and change if needed. u will see what i mean.
Hopefully you are replacing the waterpump because it was diagnosed as the problem, and not because your car is overheating and you just assume it to be the WP??
Anyway, see that thing behind the waterpump with 8 spark plug wires and a coil wire? Why that's the optispark and you don't want to soak it. Also, the screenshot of the manual does not mention that you will need to bleed air from the system with the 2 bleeder screws after you are done
