4.11 gears
just spend $150 on a good rear end girdle. if and whenyou do wad it up, replace the whole thing. you're gonna have to replace the carrier anyway if you're going from stock to 4.11:1. the gears won't mesh properly if you try to put a 4 series ring gear on a 3 series carrier, if it will even bolt up.
You don't have to change the whole housing. Just the ring and pinion gears, and the differential carrier, that is the part that the ring gear gets bolted to. Plus all other various small parts to finish the job. An entire axle with 4.11 gears won't be asy to find.
