LT1/LT4 Tech 1993-1997
396 lt1????
Old May 9, 2007 | 06:20 PM
Mr. Zero's Avatar
Default 396 lt1????
Is it possible to stroke and punch out an LT1 into a 396 or are you pushing your luck with a 2 bolt main and thinning out the cylinder walls?
Old May 9, 2007 | 06:48 PM
TheStig's Avatar
Default RE: 396 lt1????
ummm, lemme just get this strait. . .you want to boar a 350 small block out to a 396 big block???
Good luck with that. . . .
Old May 9, 2007 | 10:40 PM
95slvrZ28's Avatar
You can probably bore and stroke it up. You can stroke them out to 383 with a 400 crank, so if you bore it over you can probably get up to 396...don't cite this as fact or anything, but it seems plausible.
Old May 10, 2007 | 05:49 PM
Mr. Zero's Avatar
Can somebody inform "thestig" what makes a big block a big block and a small block a small block. I guess Chevy is wrong when they call the new ls7 "427" a small block.
Old May 10, 2007 | 05:53 PM
TheStig's Avatar
ORIGINAL: Mr. Zero
lol. . . .i was being sarcastic when i was impling that you wanted to make it a big block, Sorry I just thought it was ovious enough i wouldnt have to tell you. And besides that, i dont think you will be able to get it up to a 396. If you can great, but i dont see it happening.
Old May 10, 2007 | 06:30 PM
Mr. Zero's Avatar
Sorry for being so touchy. Was a long day. I am just curious. I know you can make a 383 out of a 350, just does not seem like 396 is that far off.
Old May 10, 2007 | 07:40 PM
coprunr's Avatar
a freind of mine owned a daily drivin LT1 that was 396 cu. in. he bought a complete kit to do it. used a Eagle crank and rods with JE pistons. here is the same basic kit http://racingjunk.com/post/432403/SM...-NEW-FORG.html
Old May 10, 2007 | 07:44 PM
396 LT1s are available, they use a crank with a 3.875" sroke compared to 3.75"stroke for the 383, and 3.48" stroke for the 350 versions.
http://www.golenengineservice.com/
