LT1/LT4 Tech 1993-1997
1996 z28 mystery battery drain - any leads?
Old 01-09-2009, 09:38 AM
Default RE: 1996 z28 mystery battery drain - any leads?
ORIGINAL: Camaro 69
ORIGINAL: z28pete
Disconnect one of the cables from the battery and insert an Ohm meter between the battery cable and the battery terminal.
For the sake of not frying an ohm meter, didn't you mean an ammeter?
Not tryin to bust your lug-nuts Pete, just making sure he doesn't cook something that isn't already!
You are absolutely correct. Ohm meter won't fare too well. Besides, can't measure current too well with an Ohm meter. lol
Old 01-11-2009, 05:27 PM
speakerfritz's Avatar
Ok, found the problem...the magical drain is the factory installed alarm system. If I use the key remote to lock the car...the battery is drained to low to start the car within 24 hrs. If I use the interior door lock switch to lock the car...car starts fine. Did this for a few days and confirmed.
Battery is new and charges at the battery terminal at 14.1 volts at idle after warm up. Battery is rated at 1000 CA and 800 CCA's.
So for now..I'll just lock the car using the door switch until I can figure out what the issue is with the factory installed alarm system is.
Old 01-11-2009, 07:31 PM
torque_is_good's Avatar
[sm=groupwave.gif]
glad that you found the culprit.
Old 01-11-2009, 07:48 PM
shawnathan's Avatar
My alarm system has done that once to but I have a garage that locks up and live in the middle of nowhere where someone could spit on the floor and the town would know about it so I just leave my alarm off unless I go to the city
Old 08-06-2010, 09:40 PM
biker.boy.82's Avatar
Im having the same issue with my 93 Z28 . It literally Ate two brand new batteries ! this problem started since I haven't been driving the car lately . Alternator is fine . As long as the car is run on a daily basis there is no problem , But park it for two days and The battery is drained so bad the auto door locks wont even work . I suspect its the damn Viper alarm system in the car (which was installed before I bought it ) I have no instructions on how to dissarm this thing . Is it as simple as pulling the fuses out of it ? or will the car not start with that done ?
I went to the viper alarm website and they admitted to problems with their older alarm models but didn't offer any help . thinking about removing the alarm all together . Any suggestions ???
Old 08-08-2010, 11:46 PM
doinnslow's Avatar
i suggest remove the alarm send it to me and ill install it and let you know if its the alarm or not
BZpbp
11-07-2012 09:22 AM
frmjersey
02-12-2009 05:29 PM
jpucci
08-19-2007 08:56 PM
jpucci
07-17-2007 09:54 PM
86 camaro
06-08-2007 01:28 AM
Quick Reply: 1996 z28 mystery battery drain - any leads?
