1996 Camaro Z28 question
Alright, i have an all stock 96 camaro z28 4 speed and im looking to make it quicker.
My budget is about 1,000 dollars, maybe a couple hundred more.
What should i buy in that price range to get the most out of my money and make it as quick as possible?
RE: 1996 Camaro Z28 question
search function is your friend. i'd start with cold air, headers, cat-back(probably most of that grand right there). then i'd do gears and stall. then suspension work to get power to the ground, then i'd look into a heads/cam package
Check out the stickies at the top of the 4th gen section, there is one titled "General Modification info-where to start modding" or something to that effect, it should explain all the basics. Once you've gone over that you can come back with specific questions. Happy reading!
