1993 Camaro Z28 engine diagnosis
yep ignition coil/control module or coil can fail after warming up. I'm sure the opti can as well although i dont recall reading about it happening. i had a icm go and it would die while going down the road then it wouldn't start for 10 or 20 minutes. starter can also lose torque after heating up causing drag but then the starter will engage it just won't turn the motor over fast enough or will engage but not do anything. I'm sure there are several other things that can cause what your seeing. flash it and see if you have anything show up. its easy and doesnt take much to do.
I think he was referring to hyrdo-lock. That would however require the cylinders to be filled with water/anti-freeze. What's the longest you've run it?
Check codes and check spark at the coil when it goes to a no start condition. ICM and/or coil could be getting hot and causing a no start.
Most part stores can test the ICM. That will at least narrow that down. If it comes back good or bad, space it away from the head with a few washers (you may need longer bolts too) to keep the heat soak down.
93 1993 Chevrolet Camaro Ignition Coil Interface Module - Engine Electrical - MSD - PartsGeek
93 1993 Chevrolet Camaro Ignition Control Module - Engine Electrical - MSD - PartsGeek
wow, 100 bucks,,, price went up sense i last bought one.
1993 Chevrolet Camaro Ignition Control Module - Standard Motor Products LX355 | StockWiseAuto
randyorton
07-22-2010 01:06 PM
