What is the diagnosis procedure to determine an engine internal water leak?
Old Jul 17, 2010 | 01:33 AM
randyorton's Avatar
Default What is the diagnosis procedure to determine an engine internal water leak?
I think my pickup has an internal water leak, it is dripping lots of water out of the tail pipe, is that consistent with an internal leak?
Old Jul 17, 2010 | 11:40 AM
are you losing coolant from the radiator? you will get a bit of moisture out the tail pipe normally.
Old Jul 22, 2010 | 01:05 PM
automotive_solutions's Avatar
there is a block check kit that checks for combustion gases in the coolant. cheap and easy.
Old Jul 22, 2010 | 01:06 PM
Does it over-heat?
what kind of truck is it?
superandy411
Jul 5, 2014 08:15 PM
antperri1222
Dec 13, 2011 06:19 PM
martynlutherking
May 25, 2010 11:12 PM
95z28htch
Mar 6, 2010 08:05 AM
MyFirstPony
70-81 V8 Tech
Jun 4, 2009 03:00 PM
