LT1/LT4 Tech 1993-1997
1978 350 motor in a 1998
Old Jul 24, 2006 | 06:04 PM
benz660r's Avatar
Default 1978 350 motor in a 1998
will a 1978 350 fit in a 1998 camaro? Also if it was a v6 camaro would it need any upgrades.
Old Jul 25, 2006 | 02:10 AM
Default RE: 1978 350 motor in a 1998
It most likely will fit if you want to chop up the cowl and the hood, but mating the '98 Camaro electronics to a small block Chevy that was not designed for them, could be an interesting challenge. This is the reason that the LT1 was developed. Seems to me you are taking a backwards step.
Old Aug 8, 2006 | 06:17 PM
Interceptor1's Avatar
I agree with Pete, that bulky HEI distribuitor won't fit under the cowl. If you need to pass emissions test where you live, the '78 engine in the newer car will fail. If you were installing the newer engine in a '78 chasis, you could pass if you kept all emissions systems as they were when new to comply as a '98 engine.
You can get an LT1 or LS1 at junkyards and engine vendors, and you know for sure it fits. I think the V6 crossmember is different, but check around I'm not sure.
Old Aug 9, 2006 | 07:17 PM
LTgun_94's Avatar
Unless this is a built 350 u will definitely be taking a step back! An LT1 or LS1 would definitely be more fit for the newer vehicle.
1998camaro
Jun 5, 2014 08:42 AM
rubberduck
Jul 31, 2011 08:25 PM
Schramm
Jul 13, 2011 08:19 AM
benz660r
Jul 22, 2006 01:06 PM
