LT1/LT4 Tech 1993-1997
02 sensor question
Old Jun 30, 2009 | 07:02 PM
Unit94Z28's Avatar
ok so i plugged it in...and the error codes were "#36 Res Failure", #38 ERG Failure, #29 Electrical Failure".......anyone have any ideas what this could be?
Old Jun 30, 2009 | 07:04 PM
Unit94Z28's Avatar
correction...that was #32 (not 38) ERG failure.
sorry.
Old Jul 1, 2009 | 11:01 PM
36 has to do with the opti. bummer. check the egr and see if it will hold a vacumm and make sure the passages are clear. dont show a 29 in my 93 book. u need to get a dealer service manual for your yr. should be able to find a better deal than this..
http://www.factoryautomanuals.com/Pr...ductCode=72684
Old Jul 1, 2009 | 11:28 PM
The problem with the OBD1 system is that an error code can stand for more than one unrelated problem. I have a secret decoder book. It says...
Code 36:
Mass air flow sensor - burn off circuit problem.
Transmission shift problem.
Direct ignition system fault - los of 24x signal or extra or missing pulses in electronic spark timing signal.
Ignition system fault - loss of High Resolution Pulse signal.
Code 32:
Barometric pressure sensor circuit failure.
EGR valve diagnostic switch - closed during engine start-up or open when EGR flow requested by ECM.
Electronic vacuum regulator valve error (controls EGR vacuum).
Code 29:
4th gear switch.
Quad-driver module or Quad-driver No. 3 error.
Secondary air injection system - circuit problems.
I guess that clears it up for you?
Old Jul 2, 2009 | 09:43 AM
Unit94Z28's Avatar
do you think that those have something to do with the shift kit i have in the car?
Camaroboi22
Feb 26, 2013 09:49 AM
Krusher RS
Jan 15, 2013 08:23 AM
Chevy101
Jul 9, 2011 07:07 PM
1983camaro
Aug 1, 2010 06:46 PM
hevymetalg
Sep 25, 2008 05:50 PM
