LS Series Tech 1998-2002
What kind of ABS does my car have??
Old Jun 21, 2010 | 01:44 PM
blue_thunder01's Avatar
Default What kind of ABS does my car have??
My car is a 2001 SS..since it does NOT have the ASR, would i have a 3-channel or 4-channel??
Old Jun 21, 2010 | 03:25 PM
18436572's Avatar
seems to be a bosh 5.3 system with or with out traction control
check to be sure if you have a wheel sensor each side at the back
it sould be a 4 wheel system by the info in the box i'm looking at
Old Jun 21, 2010 | 04:43 PM
Look at your rear wheels, if there is a sensor lead going to each wheel, it is a 4 chan system.
Old Jun 22, 2010 | 11:27 AM
Thanks for the info..i just looked at it and its got a single sensor in the middle so i believe that would be a 3 channel..
Old Jun 22, 2010 | 12:49 PM
libertyforall1776's Avatar
So do Camaros with ASR have a 4 channel system?
Old Jun 22, 2010 | 01:16 PM
ASR needs a 4 channel system because it needs to know how fast each of the drive wheels is spinning compared to the front wheels. If both rear wheels are slipping at the same rate ASR the reduces power, if only one rear wheel is slipping the ASR applies brakes to the slipping wheel.
Old Jun 22, 2010 | 11:58 PM
Makes sense.
Anyone seen a how-to article to retrofit ASR onto a Camaro that does not have it?
Old Jun 23, 2010 | 02:52 PM
maudyZ28's Avatar
why retro fit is, ASR sucks big time, its one of the worst traction control systems i've ever seen and typically pulls power when you need it to get out of a 'situation'
Old Jun 23, 2010 | 10:26 PM
Seems to work well on wet pavement for me. Definitely NOT well in the snow...
Old Jun 24, 2010 | 01:49 AM
Massey's Avatar
The ASR system is pretty much built into the car and cannot easily be added to the mix. The control unit acts as a throttle limiter and cruise control module. It takes info from the front and rear wheels as well as the tranny to know how fast everythign should be going to ascess wether to apply brake or tighten up the throttle cable. Now you all do know that you can override the throttle limiter by simply pressing the petal down harder... yea it was designed that way.
Massey
mp734
May 16, 2012 08:44 AM
Cammy 3.8lV6
Feb 16, 2010 06:28 PM
daleas88
Sep 3, 2009 10:06 AM
fortcj7
May 6, 2008 07:16 AM
Ilovecamaros98450350
Apr 14, 2006 01:44 AM
