LS Series Tech 1998-2002
Upcoming ls1 Header Install.
Old Mar 9, 2012 | 12:22 PM
Roachz28's Avatar
Default Upcoming ls1 Header Install.
I'm gonna be posting about my upcoming header installation project. I finally have mustered up enough cash money to install the stuff I bought last year and I am taking an inventory to be sure I have everything before I get started on it. I went the route of keeping cats and all my air systems because after I'm done with school I may end up relocating to a state which has emissions standards.
Right now I have: Pacesetter LTs/texas speed catted y pipe, TR55 spark plugs, rear o2 sensor deletes (can't get a tune for a little while so deletes will be needed for now) new o2 sensors for when the fronts blow.
I am just not sure what the best spark plug wire is to order, I know that the headers produce insane amounts of heat so I need to be certain that I either try to put in heat shields or get heat resistant wires or do both?
Also my car has over 105,xxx miles so I am gonna do a tune up, other than plugs and wires what other maintenance should I perform or take a look at?
any help/warnings are always welcome. Hopefully I will be able to get some pics up of the process as we go.
Old Mar 9, 2012 | 02:54 PM
Failed Devices's Avatar
Ceramic or painted LT's?
Stock wires are fine as they have metal heat shields on them already, but MSD wires are always nice as you can twist/adjust them.
Motor mounts. Seeing as your car has some miles on it, I would highly suggest looking into doing those as well. It is a difficult job, but when doing a LT install it is the best time to do them (after you remove the old manifolds and before you put the LT's on).
Take your time with it and don't overtighten the header bolts, 10 ft/lbs is all they need. Also remember the heads are aluminum and WILL strip easy if you overtorque the bolts or your alignment is off; I had this happen to me, not fun at all.
I'd highly suggest following the guides on ls1tech, they show you some tips/tricks you otherwise wouldn't have thought of.
Old Mar 9, 2012 | 10:00 PM
Roachz28's Avatar
Alright cool thanks. Yeah I will prolly look into the motor mounts as well. I have ceramic LTs.
Old Mar 31, 2012 | 10:36 PM
libertyforall1776's Avatar
A fresh set of MLS (Multi Layer Steel) Gaskets from GM or elsewhere. Some anti-seaze lubricant for the pipe fittings and clamp bolts, etc.
CamaroDreamer
LS Series Tech
18
Nov 10, 2011 09:07 AM
CamaroDreamer
Mid West
Oct 31, 2011 12:22 AM
95greenz28
May 24, 2009 12:45 PM
MudWild680
Feb 18, 2009 06:53 PM
gotalcoholmanup
Apr 3, 2006 12:52 AM
