LS Series Tech 1998-2002
tune
Old Nov 20, 2006 | 11:41 AM
o2camaross's Avatar
Default tune
wats the best thing to do? buy a programmer, most likely predator, or bring it to thunderracing and have him tune it on the dyno
Old Nov 20, 2006 | 04:41 PM
shnormo's Avatar
Default RE: tune
Are those all the mods you have done? I would save up and do something like a cam or larger injectors in conjunction with a larger MASF and throttle body to maximize the tune. But for what you have, I would recomend the predator. When you get to the more serious mods, then you need to get it tuned per application.
Old Nov 20, 2006 | 06:29 PM
JD1969's Avatar
Default RE: tune
With those mods you don't need any tuning at all. Hand helds suck for the most part and many cars lose hp with them. Save your money and get a dyno tune when you have more mods.
Old Nov 21, 2006 | 11:49 AM
o2camaross's Avatar
Default RE: tune
thats what im gonna do. im gonna wait till i get my headers and ofy pipe, and probably a throttle body and MAF. i really want to change the cam but i wouldn't know which one to get and how hard would it be any way? And should i also get new heads or do something to the heads while im at it?
Old Nov 21, 2006 | 02:01 PM
JD1969's Avatar
Default RE: tune
It all depends on what you want out of the car. When I did my long tubes I did not get a tune, the car ran fine and had no codes. Of course with a cam a tune is a must, as for what cam, again that depends on your goals. My cam is on the big side but it is still very capable of use in a daily driver its specs are .231/.237 @ .50 and .598/.598 on a 112* LSA with 4* advance ground in. This is an older TSP grind and I think there is a newer version out. With this cam, stock heads and full bolt ons I made 393 rwhp (6 speed). Better heads would add another 40+ rwhp.
auto
Nov 1, 2010 10:29 AM
forevverlost
Mar 8, 2010 07:31 PM
uncool
Aug 23, 2008 12:53 PM
kirks11
Aug 12, 2008 08:11 PM
