LS Series Tech 1998-2002
Synthetic not good in ls1?
Old Mar 22, 2011 | 06:18 PM
coopdc78's Avatar
Default Synthetic not good in ls1?
I was just reading an old, like from 2003 GMHP mag, and the say that running synthetic, and not petrolium based oild can actually harm the 2nd ring on an ls1? Is this true, cause my car is an slp and had mobil 1 put in since birth.. or has synthetics changed over the last 8 years that its safe now?
Old Mar 23, 2011 | 06:24 AM
maudyZ28's Avatar
dunno, i always use synthetic oil, i believe that is what the recommended is 5-30w fully synthetic?
i run vauxhall (GM) dexos 2 stuff from my local dealer and car is fine and happy
Old Mar 23, 2011 | 08:58 AM
SpecterGT260's Avatar
Ninja Administrator
i hope not... its all i run
Old Mar 23, 2011 | 09:26 AM
BoricuaHec01's Avatar
I highly doubt it, LS1's or V8's in general need full synthetic oil, it's mandatory.
Old Mar 24, 2011 | 01:27 AM
libertyforall1776's Avatar
Considering LS1 Corvettes came factory-filled with synthetic, I highly doubt it. It is the same engine in Camaros.
Old Mar 25, 2011 | 08:28 AM
bill2129's Avatar
i just use reg castrol gtx. synthetics are a waste of money...
Old Mar 25, 2011 | 09:33 AM
DarkKnight's Avatar
GTO Killer
LimeKnight
really? sythetic is a waste of money? might wanna do more research
i run castrol synthec and have never had a problem
Old Mar 25, 2011 | 09:48 AM
Ninja Administrator
ive been told by mechanics for a long time that you should only run full synthetic in performance vehicles.
not entirely sure of the reason why. I have been told that synthetics are finer and penetrate better, and this can usually be seen when switching from conventional to synthetic - the oil level will drop drastically after first switching as motor components soak up some of the oil
Old Mar 25, 2011 | 10:41 AM
Drastically....huh? I guess that's what happens when you use pistons made from styrofoam!
Old Mar 25, 2011 | 10:48 AM
DarkKnight's Avatar
GTO Killer
LimeKnight
i tried to spray paint styrofoam once, its visability level dropped drastically, because it melted away haha
