LS Series Tech 1998-2002
supercharger
Old Dec 1, 2006 | 02:40 AM
cgbills's Avatar
Default supercharger
if i was wanting to run a centrifugal supercharger at or around 10psi, would i need to do anything to the internals of an ls1? is it a good idea?
Old Dec 1, 2006 | 10:55 AM
o2camaross's Avatar
Default RE: supercharger
you would probably have to run lower compression pistons just to be safe. My buddy has a 2000 WS6 with a procharger running at 7 psi with no problems. he has all stock internals as well
Old Dec 1, 2006 | 11:52 AM
shnormo's Avatar
It should work with a STOCK LS1 motor. You can upgrade the cam and reflash the computer. Use premium fuel and if you do have a little spark knock, you can always install water injection.
Old Dec 1, 2006 | 08:48 PM
JD1969's Avatar
10 psi will be ok on a stock short block, but it is really about the safe limit if running on 93 octane. Remember that the tune is going to be super critical, so go to a well trusted tuner.
hotss10
2010+ V8 Tech
17
Apr 25, 2010 01:53 AM
Wingman
Oct 21, 2009 03:18 PM
Antwan
Sep 23, 2009 10:08 PM
stockv6auto
Sep 11, 2009 09:48 PM
camarohelp
Aug 2, 2008 12:30 AM
