Sticky clutch!! =(
#26
So i was coming around corner today and got on it a little for about 40 feet. Slowed down to take another turn and couldn't put it into first. I over shot the corner a little and had to reverse, but for some reason i couldnt put it into reverse for about 10 seconds.
Dont know if this gives anymore information to narrow it down to the specific problem or not. Thanks!!
Also, Sk8rax, im liking those American Racing rims!!
#27
I know that if my car is going faster than 20 mph, I can't put it into first. In the owner's manual it says, "You can shift into FIRST (1) when you’re going less than 20 mph (30 km/h)." After 20, it simply refuses. I would say definitely bleed it first and get some fresh fluid in there. If that doesn't work, I would look into getting a new slave cylinder and doing the drill mod. If you do get a new slave cylinder, buy a remote speed bleeder for sure, because bleeding the clutch without them is a pain, and you might as well since you would already be in there. Not sure how good the vac style bleeders work.
Thank you! I got lucky and they were on the car when I bought it. What I really want are the wheels from the 2002 35th anniversary edition Camaro SS!
