LS Series Tech 1998-2002
Sandpaper
Old Oct 11, 2008 | 01:36 PM
MidnightLS1's Avatar
Default Sandpaper
I used the PlasticX on my headlights yesterday, it got must of the cloudy look out of my driver side headlight, but my passenger is still pretty bad. I was going to use the 1500 grit sand paper. Is this a good grit to use or should i use a finer one? Should i wet it as well? Thanks.
Old Oct 11, 2008 | 01:40 PM
02StanGT's Avatar
Default RE: Sandpaper
When using the finer stuff, wetsanding is good.
Old Nov 2, 2008 | 09:28 PM
The Banks's Avatar
I did this a few months ago, and I wetsanded with 800 then 1500 grit, moved to toothpaste, and then Mothers Plastic Polish with a Powerball. Just be sure to apply the toothpaste about 2-3 times to help get rid of most of the 1500 grit marks. Also just use plain original toothpaste, its a very fine abrasive comprable to 2000-2500 grit, its cheaper than sandpaper, and you can get around thouse plastic nubs alot easier.
