Port and Polish
Port and Polish
I have an extra set of LS1 heads that came with my '99Z28 when I bought it. They are in fine working order but I'm considering having them ported an polished. I've looked a little bit into it and I just wanted the Stage 1 job done. How much of a power increase does this usually yield? I also plan on combinding it with a mild cam with something like 218 duration and .550 lift.
Also, if anybody knows how much it costs on average to have heads ported and polished i would like to know.
Thanks!
Thanks!
RE: Port and Polish
assuming your talking about gasket porting and polishing ... every little bit helps. pocket porting is where the real gains are tho. the machinist i use will pocket port and do a valve job for $180 bucks. probably varies a good bit depending on where you live. Sick
RE: Port and Polish
With a cam that small porting will not get you much as LS1 heads flow as good or better than many older SCB race heads. Gasket matching is all I would reccomend that you attempt. Porting is best left to a pro with a flow bench. Many times people actually hurt performance when they attempt a DIY port job.
RE: Port and Polish
ORIGINAL: chevcamdan
I never planned on doing it myself. Im gonna call around to some places and ask about it.Thanks for the info though. Maybe I'll try a little bigger cam.
