LS Series Tech 1998-2002
nitrous!!!!
Old Dec 26, 2006 | 01:03 AM
o2camaross's Avatar
Default nitrous!!!!
Im having a problem on deciding what kind of nitrous kit i want to get. What is the best kit for a LS1. PLEASE someone help me!
Old Dec 26, 2006 | 01:30 AM
shnormo's Avatar
Default RE: nitrous!!!!
I like NOS wet EFI kit for starters. What other mods do you have?
Old Dec 26, 2006 | 11:43 AM
o2camaross's Avatar
just the ones on my sig
Old Dec 26, 2006 | 12:04 PM
JD1969's Avatar
All the major companies make quality kits. Stick with NOS, NX, ZEX, Edelbrock and you will be fine.
Old Dec 26, 2006 | 03:09 PM
shnormo's Avatar
For every 50 hp you should retard your timing 1.5-2 degrees. I'd also move your spark plug heat range down one. Don't use platunms because the platnum coating can come off under high heat and pressure.
Or if you want, have a small fuel cell so it will supply racing fuel only when nitrous is applied. It is very easy to do with a wet system. Just need another SMALL fuel pump. That way timing doesn't have to be changed nor the spark plugs.
Old Dec 26, 2006 | 05:46 PM
nickdotcom's Avatar
nitrous is nitrous is nitrous, decide between wet or dry, then pick whichever brand you think has the prettiest bottle
dynotune is my personal favorite brand
Old Dec 26, 2006 | 10:14 PM
o2camaross's Avatar
thanks for all the info guys. ill keep yall posted
noer
Sep 18, 2009 05:08 PM
rockin85
Sep 12, 2007 10:10 AM
Eric89RS
Aug 31, 2007 11:48 AM
likearock91288
Aug 13, 2007 09:18 PM
traXion
Jun 16, 2007 11:38 PM
