LS Series Tech 1998-2002
Poor Gas mileage?
Old Jan 14, 2010 | 07:42 PM
u should be able to hook up a scanner and see whats going on. with the obd 2 u can do it with the right scanner.
Old Jan 15, 2010 | 05:36 AM
maudyZ28's Avatar
do you have any mods on the car?? exhaust etc?? It running rich somewhere and as craby says a block cat is a common issue.
With your 2 min run to work milage will be lower, do you drive hard all the way or just steady?
Old Jan 15, 2010 | 05:20 PM
Carl Dan's Avatar
pretty steady drive only really have one light to hit if i do. i have a hypertech i purchased and a general scan tool at my job but it's not like a tech 2 tool. just a obd2 code reader. but i don't have any check engine lights on, i doubt anything other than a tech 2 tool would add any other insight.
Old Jan 15, 2010 | 05:22 PM
Carl Dan's Avatar
also as for mod's there is a full cat back exhaust system, SLP blackwing air lid, and a SLP strut tower brace but that is all that i have noticed. i would assume the SLP parts could be stock or add on's.
Old Jan 15, 2010 | 05:24 PM
Carl Dan's Avatar
craby i checked my scan tool at my job is an AutoXray. what type of scan tool would you recommend.
Old Jan 15, 2010 | 05:44 PM
i have a innova obd2&1 and it shows alot but im sure theres better. ive heard that autoxray will but still depends on what style. do a search on it and see what comes up. mine tells u what to do for the most part. lol good for me dont have to remember directions. lol.
Old Jan 15, 2010 | 06:10 PM
Carl Dan's Avatar
the innova tool does look like it has alot more functions than the autoxray. do you know what model you have i see the 3130 and 3160 on ebay for pretty decent price.
Old Jan 15, 2010 | 06:13 PM
3140 so its probly in between or with the way things are with me its not made anymore. lol
Old Jan 15, 2010 | 06:24 PM
Carl Dan's Avatar
yea i saw a few of those but little higher priced than the others i may try replacing the plugs and wires first and if it doesn't solve it i will look further for a good scan tool. i am thinking about either E3 diamond plugs, what kind of plug wires would you recommend.
Old Jan 15, 2010 | 06:53 PM
  #20
im usin the bosh +4 platinum plugs and msd wires but thats because ive got the high output coil. if u dont want to change em for a long time get the platinum split tips. they work good.
