LS Series Tech 1998-2002
Poor Gas mileage?
Old Dec 28, 2009 | 01:58 PM
Carl Dan's Avatar
Default Poor Gas mileage?
I recently bought my second Camaro, my first was an 02 V6, now have an 02 SS. But this SS is not nearly getting the correct gas mileage it is supposed to. when i bought it it needed to have two O2 sensors replaced as well as the driver side CAT. My gas mileage before these repairs and after was approximately the same about 13MPG. and i know that the A4 will typically get worse mileage than the M6 trans. does anyone have any suggestions.
Old Dec 28, 2009 | 03:14 PM
plugged cat will foul the plugs. have they been replaced?
Old Dec 28, 2009 | 03:50 PM
Are you talking about city driving, highway, or combined? Letting the car warm up longer in the cold weather, plus winter blend gas throws off gas mileage too. Also, do you wear a lead lined right shoe? An amount of gas mileage issues can be changed by altering driving habits.
Old Dec 29, 2009 | 02:00 AM
BandidoLenny's Avatar
Do you have a check engine light?
Is the engine running right at 200 degrees? If not... a stuck open thermostat will kill your gas mileage.
Are you running super?
Is the parking brake on?
are you dragging an anchor?
c'mon... 13mpg? really?...
Old Dec 29, 2009 | 06:46 AM
have it scanned for codes and if the scanner has the option see what is going on while running.
Old Jan 14, 2010 | 06:24 PM
Carl Dan's Avatar
quite litterally 13 on stock tune and about 15 with a hypertech programmer that i just bought and i drive about 2 miles to work and on weekends tend to take longer trips but average time to work is maybe 2-4 min if i catch a bad light. i do have a remotestart on the car and warm it up in winter cold but in response to some of the other questions... no anchor, parking brake is not on, no check engine light anymore, only premium gas (but around here all gas tends to have 10% ethanol), haven't changed the plugs yet, i was going to replace the fuel filter, and possibly the MAS. any other tips?
Old Jan 14, 2010 | 06:27 PM
Carl Dan's Avatar
also the car does seem to go through all gears but at aprox 60-65mph the car runs at around 2k rpm is this common for the A4.(have very little inside the car apart from me and maybe a book bag)
Old Jan 14, 2010 | 06:35 PM
mine is at 2k at 65.
Old Jan 14, 2010 | 07:22 PM
Carl Dan's Avatar
ok so plugs are a strong possibility given the cat issue, how about poor mas sensor sound could that possibly cause the car to think there is more air than there really is and hence dump more fuel in to the chamber, causing poor mileage.
Old Jan 14, 2010 | 07:25 PM
Carl Dan's Avatar
also the shocker imo is that the car has less than 35k miles on it for an 02.
