LS Series Tech 1998-2002
are the patriot heads good
Old Jan 22, 2008 | 06:23 PM
yellabella's Avatar
Default are the patriot heads good
I was wondering because the price difference is huge between a set of afr heads and trick flow heads to patriot heads what do you guys think bang for buck what heads
Old Feb 16, 2008 | 08:53 PM
Zoilus's Avatar
April 2009 ROTM
Default RE: are the patriot heads good
ORIGINAL: yellabella
Neither! Get a Set of PRC heads from Texas-speed.com. I got the Stage 2.5's LS6 heads and made 470rwhp with them. They're listed for $1500 which is not bad but when you call they are actually $1300 or so. If you want to get the most then buy AFR's or the Tricks. But I can not justify spending 500-800 dollars more for about 5-7hp more. And patriots are cheap good heads butmake the least power out of all of them. Overall PRC's are the best for the $$$. But again if cash is no object then go for the big name brands
Some specs on the PRC's:
* 230 intake runners[*]2.04"/1.575" Stainless Steel Valves[*]PRC Double spring kit (they actually upgraded to the .660 lift spring kit now) Complete With
Springs, Titanium Retainers, Seats, & Seals
Old Feb 17, 2008 | 07:34 AM
JD1969's Avatar
Patriot seems to have quality control issues. I would spend a little more for a more reputible head.
IROC-Z86
North East
Aug 8, 2016 09:41 PM
stewroids
Mar 6, 2012 08:19 AM
68camaross396
67-69 V8 Tech
Jul 19, 2008 05:07 PM
cwalk
Jul 6, 2007 01:47 AM
