LS Series Tech 1998-2002
Passing Smog
Old Jun 12, 2010 | 04:51 PM
02ssCamaro's Avatar
Default Passing Smog
What's up people, so today I was talking to another owner of a Camaro and he was telling me it's hard for these cars to pass smog. I'm in California and it's pretty strict out here. I was wondering if you other Cali Camaro owners have the same problem or no problem at all. Thanks for your input!
Old Jun 12, 2010 | 05:11 PM
you should have it scanned for trouble codes before getting it tested. as long as its got all the stock emission stuff, is running good and you dont have any codes it should pass.
Old Jun 12, 2010 | 05:33 PM
02ssCamaro's Avatar
I don't need to smog it for another year or so, but I posted in another section a code I am getting. The code is p0403 which is the catalytic converter. They said bank 2 passenger side but they also said it can be the driver side too which makes it more confusing. I read somewhere that the 02 senors should be replaced around 60,000 miles and I'm at 67,000.
Old Jun 12, 2010 | 06:00 PM
start saving and get both cats and both 02 sensors. a bad 02 sensor can cause a cat to fail early by giving false lean readings.
bryns81z28
Mar 9, 2010 02:12 PM
1981TypeLt
Nov 3, 2008 04:22 PM
Andross
Jul 25, 2007 04:31 PM
LSONE
Aug 11, 2006 11:40 PM
