LS Series Tech 1998-2002
Ok, need some advice and ideas on a problem!!
Old Jun 1, 2010 | 05:32 PM
KissMyTush's Avatar
Default Ok, need some advice and ideas on a problem!!
I have a 99 Z28 6Speed. As far as I know it has the Stock clutch and stock transmission. But when I am driving down the road the transmission sounds like it is roaring, usually over about 45mph. It's the worst when cruising in 6th gear at about 65-80mph! Does anyone have any ideas or advice on what could be causing it?
Old Jun 1, 2010 | 05:39 PM
You didn't happen to put Esso gas in your tank, did you? lol
Have you checked the oil/fluid level in the trans?
http://www.youtube.com/watch?v=J-qot-tlLrw
Old Jun 1, 2010 | 06:13 PM
thelastboyscout's Avatar
Extension shaft end bearing
Old Jun 1, 2010 | 09:06 PM
KissMyTush's Avatar
Lol! Nope I only use 93 octane. But thanks, i will check the Fluid and see where it is.
KissMyTush's Avatar
Where is this located? Is it inside the Transmission Housing?
Old Jun 1, 2010 | 11:09 PM
does it vibrate? can u feel it and if so where,,, seat of pants, steering wheel, shifter, clutch peddle? could be throw out bearing, universal joint, transmission failing.
Old Jun 1, 2010 | 11:26 PM
KissMyTush's Avatar
There isn't any vibrations, it shifts smooth, clutch grabs and does not slip, it just roars really loud!
Old Jun 1, 2010 | 11:27 PM
KissMyTush's Avatar
Where is the Extension Shaft end bearing located?
Old Jun 2, 2010 | 04:14 PM
Its the bearing on right at the end of the shaft
I think this is the right picture. The symptoms are usually little to no noise in 1-4 and
more noise in 5th and 6th with even more noise under load in those gears.
http://image.chevyhiperformance.com/...trans_04_z.jpg
I am assuming you checked fluid level already?
Old Jun 2, 2010 | 11:23 PM
KissMyTush's Avatar
I just got home after my trip and have not had a chance to check the fluid level. I will tomorrow. So this Extension Shaft End Bearing is inside the transmission? And yes, those are the exact symptoms. Barely any noise in 1st-4th, then more noise in 5th-6th(and much more when under load)! But like I said, I will check the fluid levels tomorrow. I'm going to change the engine oil too. I got the Windows working thanks to RSSSCamaro. The solder points in the BCM were worn out. I re-soldered the points and now it works fine. Now all I have to do is get a new radio, new power steering pump, and find out whats wrong with the tranny. Then it should be done, until I repaint it!
