Ok, need some advice and ideas on a problem!!
I have a 99 Z28 6Speed. As far as I know it has the Stock clutch and stock transmission. But when I am driving down the road the transmission sounds like it is roaring, usually over about 45mph. It's the worst when cruising in 6th gear at about 65-80mph! Does anyone have any ideas or advice on what could be causing it?
You didn't happen to put Esso gas in your tank, did you? lol
Have you checked the oil/fluid level in the trans? http://www.youtube.com/watch?v=J-qot-tlLrw |
Extension shaft end bearing
(Post 428305)
Have you checked the oil/fluid level in the trans? http://www.youtube.com/watch?v=J-qot-tlLrw Lol! Nope I only use 93 octane. But thanks, i will check the Fluid and see where it is. |
Originally Posted by thelastboyscout
(Post 428320)
does it vibrate? can u feel it and if so where,,, seat of pants, steering wheel, shifter, clutch peddle? could be throw out bearing, universal joint, transmission failing.
Originally Posted by craby
(Post 428418)
(Post 428320)
Its the bearing on right at the end of the shaft
I think this is the right picture. The symptoms are usually little to no noise in 1-4 and more noise in 5th and 6th with even more noise under load in those gears. http://image.chevyhiperformance.com/...trans_04_z.jpg I am assuming you checked fluid level already? |
(Post 428530)
