LS Series Tech 1998-2002
Ls1 Oil pressure
Old May 3, 2009 | 10:48 PM
Line em Up's Avatar
Default Ls1 Oil pressure
Ok i run synthetic oil in my camaro and i only have about 20 lbs of oil pressure when im driving down the road when the car is warmed up. when its cold it runs at 40 lbs is this normal or should i have higher oil pressure.
Old May 3, 2009 | 10:56 PM
Saint_Ali's Avatar
20lbs while driving is pretty low,id get a mechanical gauge hooked up,the factory gauges can and usually are off
Old May 3, 2009 | 11:11 PM
Line em Up's Avatar
is there anything i can do to make the stock gauge accurate case i dont really want to get any more gauges xpt nitrous pressure and air/fuel ratio.
Old May 4, 2009 | 02:24 PM
Fterr99ss's Avatar
Yea i agree with Ali that is pretty low. id go to a garage and get some for pressure test to see whats up
Old May 4, 2009 | 02:40 PM
Saint_Ali's Avatar
i dont mean,hook up a small mechanical gauge in your car.Take it to a shop and have them test the pressure with a hand held mechanical gauge,it could just be the oil pressure sending unit,they go bad all the time.
royco95
Aug 2, 2015 10:25 AM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
angelus
Feb 20, 2010 01:17 PM
divineal
Oct 23, 2009 12:21 PM
IBSTROKIN
Sep 9, 2009 10:40 PM
