LS Series Tech 1998-2002
low coolant sensor
Old Sep 23, 2013 | 07:26 PM
Z28Camaro98's Avatar
Default low coolant sensor
Is it possible for the low coolant sensor to fail? My low coolant light has come on and had stayed on for several days. Checked my radiator cap and it is full as well as my surge tank. thanks.
Old Sep 24, 2013 | 01:47 AM
MKCoconuts's Avatar
Yes it can. See number 13 in the link provided. And yes, it still applies to your LS.
4th Gen LT1 F-Body Tech Aids
Old May 15, 2014 | 10:47 AM
dleo85's Avatar
I also have a 98 Camaro Z28 which had ongoing issues with the coolant level sensor. Once I changed it and bled the air from the system, I had no more problems.
Old May 15, 2014 | 09:55 PM
GaryDoug's Avatar
The sensor eventually leaks coolant into the electronics and then it's history. I have taken apart several and seen the coolant stains on the circuit board.
Old May 18, 2014 | 05:07 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
The sensor is there as an idiot light anyway, just keep an eye on your coolant levels every now and then and you'll be fine
Old May 21, 2014 | 09:00 AM
boone's Avatar
I ran into the same issue. After replacing the sensor twice, I finally decided to unplug the thing and stop throwing money at it. I just check the level periodically.
Old May 22, 2014 | 10:42 AM
dleo85's Avatar
Yeah the sensor really isn't necessary. I didn't bother to fix it until I decided to sell the car.
Tipsy
Sep 18, 2013 08:44 PM
Triangle12
Jun 28, 2012 08:34 PM
LethalQuicksilver
Aug 3, 2010 11:45 AM
EagleRex
Jul 20, 2010 03:36 PM
qmracer
Dec 13, 2007 06:16 PM
