Low Coolant Sensor
Old Dec 13, 2007 | 04:14 PM
qmracer's Avatar
Default Low Coolant Sensor
So today on my way home froom school my low coolant light comes on as I am pulling onto my street. When I get the car home I noticed a lot of smoke coming from under the hood and it really started to worry me. upon further inspection I noticed that the sensor on the back of the radiator on the right side had somehow blown off and was just hanging by the wires. I hooked it back up and refilled whatever coolant I had lost but the light is still on and I don't know why. The manual says the light should go out once i turn the car off but it hasn't so I am asking you gys. Do I need to reset something or do you think my sensor went bad while dangling around?
Old Dec 13, 2007 | 06:04 PM
Default RE: Low Coolant Sensor
Unplug the wires drom the sensor and short them with a jumper. If the light goes out then the sensor is bad. If the light stays on, there is a broken wire.
Old Dec 13, 2007 | 06:16 PM
qmracer's Avatar
Thanks for the reply pete but the light actually went out after restarting the car like 6-7 times. Not in a row but just from driving. The time it did go out I was parked on a fairly steep hill however. Either way the light went out and there is no more smell so I think I am good now. Thanks.
Z28Camaro98
LS Series Tech
May 22, 2014 10:42 AM
Tipsy
Sep 18, 2013 08:44 PM
Triangle12
Jun 28, 2012 08:34 PM
LethalQuicksilver
Aug 3, 2010 11:45 AM
EagleRex
Jul 20, 2010 03:36 PM
