LS Series Tech 1998-2002
This is just getting a little old
Old Jul 31, 2006 | 09:58 PM
2002CamaroSSM6's Avatar
Default This is just getting a little old
Alright I'm having a hell of a time switching out my sparkplugs. The first 6 were fine but the last two on the passenger side is a mess it seems almost impossible, obviously it is possible but since I'm new to the ls1 its not that easy. I just want to know some hints and tips to get the job done. Would it be best if I unbolt the motor mount on the passinger side and jack it up and get it from the bottom, unfortunatly my arms arn't exactly tiny so trying to fit between the motor sucks. Any help would be greatly appreciated
Old Aug 1, 2006 | 01:51 AM
JD1969's Avatar
Default RE: This is just getting a little old
Remove the coil packs and you will have alot more room. Remove the whole mounting bar as an assembly and when you put it back on leave the furthest back nuts off, you will see why when you go to take them off.
Old Aug 1, 2006 | 02:16 AM
Well it makes since now to bad I was just a little lazy to think of it on my own. Thanks
