LS Series Tech 1998-2002
how to make an ss an 11 second car
Old Mar 20, 2009 | 11:08 PM
Antwan's Avatar
Default how to make an ss an 11 second car
how much do i have to do to make an 02 ss camaro run an 11.5 quatermile...because my buddy has a foxbody that hes done a ****ton of work to (like over 10 grand just under the hood) and he says it'll run an 11.9 and he badmouths camaros all the time...so i was just wondering what it would take to beat him. could i do it with just all the boltons...big *** heads and cam...and a built 12 bolt with 4 10's
Old Mar 21, 2009 | 09:49 AM
Saint_Ali's Avatar
yeah do full bolt ons,full exaust,heads,cam,and gears and you should get there.now the idea is not to put the biggest heads and cam you can find,you have to get them matched to work with your goals.putting too large heads and cam could actually hurt you.
Old Mar 21, 2009 | 10:25 AM
robmnrd's Avatar
If you want mid 11s and without giving up all drivability, here's what I'd suggest:
Full bolt-ons (including gears), light porting/polishing of the heads and intake, a relatively small cam (as Alih said it has to match the setup. bigger isn't always better), a 100 shot of nitrous, and a few suspension goodies. That, some sticky tires, and the driver mod will IMO get you to mid 11s.
Old Mar 21, 2009 | 12:14 PM
Antwan's Avatar
why not put the biggest heads and biggest cam i can get ? and then just build the bottom end down the road
Old Mar 21, 2009 | 12:52 PM
z28rob18's Avatar
ok for an ls1 camaro it does not take that much to hit mid 11s a full suspension with full exhaust and run mid 12s you do that and shoot a 100 shot you got mid 11s. i watched an ls1 car run 10.76 with a cam bolt ons and suspension. it depends on wat you want to do to get there. you could spray a 150 shot with a full suspension sticky tires exhaust and cai and you should hav your 11.5
Old Mar 21, 2009 | 01:38 PM
SpecterGT260's Avatar
Ninja Administrator
you dont want to go too big because if you develop choke points in the air flow, and reservoirs you end up losing power. over-camming can lead to a car falling flat on its face. no torque due to overlap of lobes, no high rpm hp due to restrictions of other parts.
Old Mar 21, 2009 | 01:50 PM
cbr600rx7's Avatar
A lot depends on how you want to get there. If this is a A4 car a good converter can make a huge difference. If its a M6 then a strong clutch is a must. A lot will come down on traction so 555Rs or MT's are going to be a must at the minimal. A good set of 3.73s or 4.10s will also cut off some good time once you have the traction.
A 3200 stall, with 4.10s and say a mild 125 shot with say lid, y-pipe, exhaust, and tune should go 11.5 with no problem as long as you can hook (once again traction goes a long way) and still be able to run 12.5-12.7 with out the bottle.
If you want to stay away from the spray then your in for a little bit of work. Tires, converter, and gears are still going to be good investment but your going to need a good head/cam package with headers to make get into the 11s.
Once you get into the 11s your rear end is going to go in only a matter of time. If its a m6 car its going to be sooner then later.
Good luck and keep us up to date.
Old Mar 23, 2009 | 08:46 PM
Antwan's Avatar
now guys keep in mind i dont have a car yet ! im just getting info but im looking for one with about 45000 miles on it for about 13,000...and i was wondering what the ss would run with a full exhaust, high flow cats, headers, slp intake kit, bigger mass air meter, bigger throtle body, and 555's ? on and its deffinetly gotta be a 6 speed ? can someone give me an estimated time in the quarter
Old Mar 24, 2009 | 09:56 AM
Ninja Administrator
mid 12s if you hook well. but i dont know if the TB and MAF are really important mods at that point. depending on year I would get the ls6 intake manifold (which i still need to get dangit) and then worry about the tune. the stock TB should flow plenty until you have a cam in there, but all the same i dont think it will hurt you any.
Old Mar 24, 2009 | 12:03 PM
95slvrZ28's Avatar
I tend to agree with Spec here. Don't waste your money on a new MAF or TB, you need to be making some serious power before you need to look into upgrading those. Focus on intake, full exhaust and some good tires so you can actually use the power you're making.
Side note: Speaking of LS6's my dad just got headers for his Z06...this is going to be sweet...
