LS Series Tech 1998-2002
How do I get the diverter valve out?
Old Dec 21, 2014 | 01:09 PM
Corvette_Mike's Avatar
Default How do I get the diverter valve out?
I have a 2002 SS camaro. I need to change out the diverter valve. Any suggestions on how to get this piece out? Seems tight where it is located. Thank you for your replies.
Old Dec 21, 2014 | 06:26 PM
diverter valve for what? download a manual here, see if that helps, http://www.mediafire.com/?40mfgeoe4ctti use the 2000 fb file, some crazy guy was kind enough to post them. garydoug,,,
Old Dec 21, 2014 | 08:16 PM
diverter valve for the smog pump. Its located on top of the driver side engine way back under the dash. I have the factory shop manuals and it shows a bolt on the back side of the head. I was hoping for an easier way to get this diverter out. I am getting the P0410 code. I have already changed out the check valves.
Old Dec 21, 2014 | 09:55 PM
GaryDoug's Avatar
I assume you are getting airflow at the hose from the pump but no flow at either pipe at the manifolds, right?
Have you checked for engine vacuum to (and from) the small solenoid just in front of the cutoff/diverter valve?
Old Dec 22, 2014 | 05:28 AM
Im getting lots of air at the hose going over the fender when I take the hose apart at the union. Im getting vacuum to the diverter valve. Im not getting much air at all to both check valves.
Old Feb 14, 2015 | 08:40 AM
I still need to change out my diverter valve on my 02 Camaro SS. LS1 engine. I cant figure out how to get it out because of the limited space. Anyone have any tips on how to R&R this piece?
Thank you
Red Bull
Feb 22, 2010 09:24 AM
avalonjohn
Nov 4, 2009 05:31 PM
79camaro505
Feb 22, 2008 08:02 PM
cdoyle
Aug 13, 2006 12:32 PM
