LS Series Tech 1998-2002
horse power question...
Old Mar 9, 2007 | 03:41 PM
99SLPSS's Avatar
Default RE: horse power question...
say i get the 90mm, i have and LS6 intake manifold (i have a 99 it didnt come with the LS6-as your prolly know), is that what you were talking about or would i need to get a different one?....would i see a difference in perfromance out of my car?
Old Mar 9, 2007 | 05:19 PM
SSsuperdave's Avatar
The 4.10 hasn't hurt my top end that i've noticed. 5th gear will still pull all that's on the speed-o! But who runs that fast on a regular basis? I get more enjoyment from out the hole to 115 anyway. As for your t-body question, I'm putting a BBK 80mm on the LS6 intake I just bought, so I'll let you know soon afterit's all done and dynoed.
Old Mar 9, 2007 | 06:53 PM
o2camaross's Avatar
If you were to get the 90mm TB you would also have to buy a FAST manifold, It wont bolt up to an LS1 or an LS6 manifold
Old Mar 9, 2007 | 07:56 PM
99SLPSS's Avatar
thanks superdave and 02ss....i appriciate it, i dont think ill go with the 90mm then if i have to get a whole new intake manifold, but def let me know how the 80mm goes superdave, i may go down that route.....and your right as far as the top speed, i dont and wont run it that fast that often but its nice to brag that it will bury the speedo,.....i think i may go with the 4:10s as well if it dont hurt top end that bad...thanx
Old Mar 9, 2007 | 09:06 PM
Lee Willis's Avatar
I would not bother with a 90 mm throttle or fast 90 mm intake manifold unless you have re-done heads and a cam. A stock engine really can't use the added capacity.
Old Mar 11, 2007 | 10:15 PM
TuftsAuto's Avatar
I was under the impression that the rear end isn't really strong enough to take 4.10s in the rear safely. Doesn't it often break from that?
Old Mar 12, 2007 | 01:13 AM
Lee Willis's Avatar
ORIGINAL: TuftsAuto
All the time. Count on replaceing it soon. They are the weak link. Nothing you can do about it except replace it.
Old Mar 12, 2007 | 01:54 AM
95slvrZ28's Avatar
Sounds like someone needs 4.10's in a Ford 9 inch rear end
1bad96Z28
Jun 27, 2007 11:01 PM
Jims94LT1
Jan 1, 2007 10:38 PM
83_camaro
Dec 13, 2006 10:47 PM
