LT1/LT4 Tech 1993-1997
horse power???
Old May 18, 2007 | 05:18 PM
1bad96Z28's Avatar
Default horse power???
ok ive got 6k to build my motor. i want between 400-500 hp to the wheels. or around 10-11sec on the 1/4. someone told me (which i say there full of it) that if i wanted that much hp to the wheels that i would have to have 1000hp in the motor. to the crank. well like i say i think there full of it and i know they are but im doing this to prove them wrong. he said "hp from the crank to the wheels is halfed. basicly what you have to the crank, half of that will be your whp. example, the z28 has 285 hp to the crank. so you would have about 140hp to the wheels." same as he says if you run 140 in the quarter your in 7 seconds.
Old May 18, 2007 | 05:35 PM
95slvrZ28's Avatar
Default RE: horse power???
Ha...haha...ha....heh...ya, 50% drivetrain loss, not likely. Most of the time a good general number for drivetrain loss is about 15%. To get some good HP out of it, you'll need heads, cam, ported/polished intake manifold, throttle body, full header back exhaust, CAI. That may...may get you close. To the the times down, some 3.73 or 4.11 gears would help. If you still need HP, then you're probably either have the option of nitrous(boo!) or getting a new bottom end and stroking it out to a 383, in which case you'll want new crank, pistons etc. pretty much rebuilding the motor completely...
Old May 18, 2007 | 05:52 PM
74454bb's Avatar
May 2007 ROTM
to see 10's and low 11's youl need over 550 HP, 600 to be safe, and thats with alot of work to the suspension, and some fat slix.
Old May 18, 2007 | 09:30 PM
I_Have_A_Camaro_GT's Avatar
https://camaroforums.com/m_81132/mpa..._/tm.htm#81394
check that out it will tell you everything you need to know on how to make your car fast with a leaf blower. 6k you could do the twin leaf blower set up.
Old May 20, 2007 | 02:47 PM
1bad96Z28's Avatar
um yeah about the leaf blowers. i think i might be going tooo fast for that. "" id rather do twin turbos mounted where there sticking out of the hood.
Old May 20, 2007 | 02:51 PM
1bad96Z28's Avatar
95slvrZ28. thanks for you advise. im going to fully build the motor. and i want to run at least mid high 11s. thats not alot to shoot for. and ive already done work on the suspension. sub frame connectors and new sway bars. and ive already got 3.73s i believe. ive got at least 6k to build this motor with. but i just dont want to have the thing go boom. everyone is telling me to buy crate motor. the one im looking at is a zz350 with 365 hp to the crank and thats 5200$ but its full turn kee engine. and advise is very appreciated.
Old May 20, 2007 | 04:16 PM
74454bb's Avatar
May 2007 ROTM
That would be a good motor to get, look around there are other crates out there that may have more....check out the 383 crates as well.
Old May 20, 2007 | 11:36 PM
1bad96Z28's Avatar
yeah im going to go up to the chevy dealership and talk with them about what motors they can get. ive looked on jegs but all are carb. i want fuel injected.i dont know any good sites to look at for the crate motor. but i really appreciate the advise. people say go with a crate cuz of waranty. my brother has 15years of work on cars and he can build bad *** motors but hes built them and they made a few passes and came to peices. had it shipped off to find out why and they couldnt even find out why it did it. i want a bad *** car. but i also dont want to waste the money. ill show you a guy thats got a bad *** camaro.
Old May 20, 2007 | 11:47 PM
1bad96Z28's Avatar
this guy has one bad *** car. and i want mine like this. his is an ss but still. soon mine will be this good. watch the movie. these are the mods to his engine that hes telling who knows whats there hes not telling
http://vids.myspace.com/index.cfm?fu...eoid=916077455
These are the new mods I did to my LS1 engine over the winter, I still need a proper Dyno tune, and I have not been to the track yet with these mods, but here they are:
Camshaft: Thunder racing T-Rex Cam: duration @ .050 lift 243/249 lift .612 intake/.629 exhaust
Heads: Ls1 ported and polished
Valve springs: Crane Cams dual valve springs, Titanium retainers, and springs seats
Push Rods: Comp Cams heat treated chrome moly push rods
Intake Manifold: Weiand intake
Headers: Edlelbrock long tube headers and race Y-pipe
Exhaust: SLP loudmouth 2
Timing chain: Cloyes timing chain
Gaskets and seals: Fel-Pro
Cam Bearings: Clevette bearings
Main and rod bearings: stock GM Bearings
Crankshaft: Stock LS1 Crankshaft
Mass air sensor: SLP Mass Air Flow
Cooling system: Hypertech 160 degree low temp thermostat
Intake: SLP cold air intake, SLP lid w/K&N filter and smooth below
Plug wires: MSD 8mm Ignition wires
Spark plugs: AcDelco Iridium spark plugs
Rear End gears: Richmond 4:56 gears
Rear lower trailing arms: Lakewood boxed trailing arms
Torque arm: Edelbrock Tubular torque arm and solid mount
Sub-Frame connectors: Jegs high performance brand
Springs: Eibach Sportline
Drag Radials: Nitto 275/45R17
Old Jun 1, 2007 | 05:52 PM
LT1RUNNER's Avatar
You can also try Golen Engine if you want to go the crate engin rout. The have LT1/LT4 engines ranging from 375hp to 520hp. Prices range from 4g's and up.
