LS Series Tech 1998-2002
Help with exhuast selection
Old 06-16-2016, 09:26 PM
Warren02SS's Avatar
impossible. If i switched L pipes the hangers would be aimed toward the ground.
  #22
Old 06-17-2016, 01:04 AM
i would sure be tempted to modify it.
  #23
Old 06-17-2016, 03:54 AM
Warren02SS's Avatar
Yep, I was tempted to modify it and it got the best of me. After a few hours of heating, bending, cutting and adjusting I think I got some decent results. First, I cut down the hanger to the correct height and then bent it to the correct position. Then I cut about 3/4 inch off of the driver side outlet on the muffler and the same off of the inlet on the driver side tail pipe that way it could be pushed more toward the center of the car.
The passenger tail pipe is pushed as far off of the muffler as possible without leaking (you can see where the clamp is) so the tip can move away from the center. Before The driver side tip was 10 3/4 inch from the center and the passenger was 9 1/2 inch, Now its about 10 1/4 inch on the driver side and about 10 inches on the passenger side. Its still not perfect but good enough. Its also nice to see the hanger working as it should now.
  #24
Old 06-17-2016, 06:32 AM
kool, looks good, big question, how does it sound.
  #25
Old 06-17-2016, 08:09 AM
Everett#2390's Avatar
Nice fix - always scary of aftermarket fitment.
Is the '04 sticker on the license plate an overlooked item?
  #26
Old 06-17-2016, 10:41 AM
Warren02SS's Avatar
I like the sound has a deep mellow rumble at low rpms, pretty quiet when cruising around and gets a little louder during spirited driving. Best of all no drone. I forgot to mention those measurements are to the edge of the license plate on that side not to the center of the car. The 4 on the plate is the month not the year good till 4/2017.
  #27
Old 07-01-2017, 08:42 PM
fstr n u's Avatar
Sorry...texas speed tru duals....everyone around loves the sound of these cars...no need to be quiet!
alex5366
12-04-2015 11:50 AM
toyotajeep
02-13-2011 01:38 PM
rollnw24inkmc
07-03-2007 08:45 PM
Nirvana._69
04-03-2006 11:06 PM
sewerrat
82-92 V8 Tech
07-23-2005 07:24 AM
Quick Reply: Help with exhuast selection
