LS Series Tech 1998-2002
Harmonic Balancer
Old 10-04-2009, 12:22 PM
jarrod1875's Avatar
Default Harmonic Balancer
I was needing to replace my harmonic balancer on my 2000 Z28 and I was told it would be a good idea to replace it with a performance one. Is that necessary? Which one would you recommend? I have to idea what to get. What's the difference in % under drive? and dampers? If ANYONE could help I would really appreciate it. Thanks!
Old 10-11-2009, 07:58 PM
KPI's Avatar
KPI
KPI is offline
Not necessary.
I have ASP. SLP sells ont too. Slp has a key, ASP doesn't.
10% underdrive means you're turning the water pump, power steering, alternator, & AC 10% less than the oem pulley.
If you have a big power-consuming stereo system,you might need an overdrive alternator pulley with an underdrive crank pulley.
LS1 is internally balanced and the crank pulley isn't a damper.
Old 10-12-2009, 12:00 PM
jarrod1875's Avatar
So do you have any recommendations on what I should get?
Thanks
Old 10-27-2009, 07:22 PM
KPI's Avatar
KPI
KPI is offline
Sorry for the delayed response. I'd probably get the SLP if I were buying today .I think it comes with an oem crank bolt, but I'd get an ARP crank bolt too.
Old 10-29-2009, 12:45 PM
jarrod1875's Avatar
Thanks. Appreciate all the help.
drifter
08-12-2013 07:00 PM
1976camaro
70-81 V8 Tech
12-14-2010 12:28 AM
camie
67-69 V8 Tech
03-16-2008 12:28 PM
chrshadil
08-20-2007 10:00 PM
chrshadil
08-12-2007 09:03 PM
Quick Reply: Harmonic Balancer
