LS Series Tech 1998-2002
gears
Old May 7, 2007 | 11:34 PM
o2camaross's Avatar
Default gears
Ok, im about to buy a Moser 9 in and im not sure what gears to get. I kno its either gonna be 3.89's or 4.11's. I want decent gas mileage but i want it to pin me back in my seat at the same time. A couple of people tell me that 4.11's is too much. By the way i have a T-56. One of the options with the rearend is full spool, posi trac, or a detroit locker. I kno what posi-trac is but im not too familiar with the other two, could someone explain them to me?
Old May 8, 2007 | 12:18 AM
JD1969's Avatar
Default RE: gears
People who say 4:10's are too much with a T56 have their heads WAAAAAYYYY up their ***.
Old May 8, 2007 | 10:48 AM
o2camaross's Avatar
Default RE: gears
well that settles that, but what about the differential deal?
Old May 9, 2007 | 10:19 AM
o2camaross's Avatar
Default RE: gears
any one?
Old May 9, 2007 | 08:41 PM
nickdotcom's Avatar
Default RE: gears
a locker is 100% torque to both wheels equally all the time when there is forward motion
a spool does basically the same thing but without the racheting like the locker and is really only for racing
horsepower tv had a special a while back about all different rear end styles, maybe you can DL it
Old May 9, 2007 | 09:47 PM
o2camaross's Avatar
Default RE: gears
thanks
Old Oct 4, 2007 | 06:17 PM
chrismorales75's Avatar
Default RE: gears
I've ran a spool car on the street and it sucks a little for u-turns. If you plan to do a lot of street driving I'd get the locker, if it is your weekend fun car and you like to drag race it a lot, I would get the spool. I would get 4.11 gears with a t-56.
I have a t-56 and have run 4.10's and they work great for mild LS1's, once you run over 116-118 mph you'll either have to go to a taller tire 28" or less gear, i.e. 3.89 or 3.73 for 1/4 drag stuff to not run out of rpm.
If you have an aftermarket cam and can turn a little more rpm then 4.11's should work great all around for a while.
Also 40 spline gun drilled axels are only 200.00 more and are stronger and lighter than 35 spline soild axels, just a thought.
sepadowd
Aug 4, 2011 07:59 PM
91camaro350
82-92 V8 Tech
Aug 5, 2010 10:28 AM
gfrench
Jun 19, 2010 10:16 PM
1bad96Z28
Jun 9, 2007 09:12 AM
