LS Series Tech 1998-2002
engine knock
Old Jun 5, 2007 | 10:17 PM
mikes 2002z28's Avatar
Default engine knock
hello everyone i have a 2002 Z28 with the LS1. IT has a engine knock until It warms up to temp.just wondering if this is a normal thing with the LS! thanks you for any info.
mike
Old Jun 5, 2007 | 10:44 PM
Default RE: engine knock
Are u sure it is an engine knock, or just a valve lifter making noise till it pump up?
Old Jun 6, 2007 | 01:53 PM
thks for the re ply.It could be lifter noise it has only 35000 mi on it.
but when i first start it there is no noise after a min or 2 is when the noise starts .
then once the engine gets up 2 temp it goes away.
if i go to town and shut it off for 5 2 ten min. and restart it u can again until it gets back up 2 full temp. was thinking that mabe this was normal for the ls1 ???
thanks again
mike.
Old Jun 6, 2007 | 04:03 PM
JD1969's Avatar
Could be what is known as piston slap, it's pretty common in LS1's
Old Jun 6, 2007 | 04:27 PM
Deagle85's Avatar
I have that same knocking noise in my ls1 at the same time's as well. I think it might be what JD is talking about, piston slapping. Its common. Just get a loud exhaust system to drown it out lol I can't wait to put some louthmouth's on mine
Old Jun 6, 2007 | 05:28 PM
thank you for the reply. yes i think u are right. i made a phone call to slp and they said the same thing.
thanks again
mike
[IMG]local://upfiles/8297/9BB5741EC30346539270F68243252F86.jpg[/IMG]
Old Jun 6, 2007 | 05:38 PM
just want 2 say thank you. for everyones help.
Old Jul 12, 2007 | 11:28 AM
1970judge's Avatar
Piston slap. From the factory there is a almost five-thousandths of clearance as opposed to a standard SBC with 2-3. The extra clearance gives the aluminum room to expand when hot.
evilemokid94
82-92 V6 Tech
Mar 15, 2011 09:01 PM
xrmini23
Oct 18, 2009 07:35 PM
retroj23Z28
Sep 28, 2009 10:32 AM
Mattox
Sep 7, 2009 05:51 PM
cerecker
67-69 V8 Tech
Apr 18, 2009 07:02 AM
