LS Series Tech 1998-2002
Cold air intake or bigger lid?
Old Sep 18, 2008 | 01:38 PM
MidnightLS1's Avatar
Default Cold air intake or bigger lid?
Is it worth it to spend the extra money to put on a cold air intake, or should i just stick with a larger air lid?
Old Sep 18, 2008 | 02:51 PM
maudyZ28's Avatar
Default RE: Cold air intake or bigger lid?
i went for the bigger lid myself, something like the slp one, but you can mod the air tray underside by cutting it out and removing the plastic over the radiator too, this will draw cold air in from under the car just take it steady in wet as you dont wanna suck up water spray
Old Oct 3, 2008 | 11:54 PM
Zoilus's Avatar
April 2009 ROTM
the cold air intake benefits a bit more at higher speeds if you have an SS hood. Like my Volant CAI. But if you don't have the hood a regular aftermarket lid will do although some are known to have fitting issues and the CAI wont have such a thing happen. My Carbon lid never fit right. I love my volant...it looks different and works great
Old Oct 4, 2008 | 07:06 AM
rsh3429's Avatar
I just installed a SLP lid and am dissappointed with the fit, doesn't sit on the airbox well. I'll probably start researching Volant. Good Luck
Old Oct 4, 2008 | 07:00 PM
So what brand would you suggest of air lid? I just checked out the Volant intake system, you think its worth it?
Old Oct 4, 2008 | 11:04 PM
Zoilus's Avatar
April 2009 ROTM
ORIGINAL: MidnightLS1
if you are going to get just bolt on's then a lid will do. I would leave the $$$ for the volant only if you are going to do heads, cam..etc later on down the line.As far as lids...just like stated above, even the SLP ones are hit or miss. Sometimes they fit perfect and sometimes they just don't.
Old Oct 6, 2008 | 02:58 PM
Is there a better lid than the SLP? I just thought since they worked with the F-body cars so long that they would be good.
Old Oct 6, 2008 | 08:20 PM
Zoilus's Avatar
April 2009 ROTM
nah pretty much a lid is a lid it doesn't matter which one. Other makers besides SLP, make clear ones, carbon fiber, or you can take one of those and have it custom painted thru various sites choice is all up to you
Old Dec 29, 2008 | 05:35 PM
Gordon's Avatar
GM High Tech Magazine did a side by side comparison test with about 8 different lids. While the differences between the 8 were minor, the SLP did perform the best as far as air flow was concerned. SLP has re-engineered their lid and it is supposed to flow even better.
I went with an SLP CAI set up (including lid, smooth bellows and trimming the plastic under the K&N) and am very pleased with the results.
I am thinking of making my own version of the SSRA (Super Sucker Ram Air). Google that and you'll see what I mean.
Old Jan 2, 2009 | 04:57 PM
libertyforall1776's Avatar
Get BOTH. Either SLP FloPac or FLP's products...
crimson09
Dec 15, 2018 07:07 AM
luciora
Apr 11, 2013 11:17 AM
Sean1995
Sep 15, 2009 07:37 PM
concept225
82-92 V8 Tech
Jul 29, 2009 07:46 PM
ninetysixyenko
May 11, 2007 11:34 AM
