slp cold air intake
Old Jul 23, 2009 | 02:42 PM
Sean1995's Avatar
Default slp cold air intake
i have a 1995 z28 camaro Lt1 motor 5.7 liter 350. I want to make it faster what should I do? I was thinking slp cold air intake and bbk throttle body. Does any one know a good place to get parts and any suggestion on what other performance idea I can do?
Old Jul 23, 2009 | 03:02 PM
evilkal's Avatar
Don't mess with the throttle body. Yours is fine... Go with a cold air intake and a catback exhaust. That is the best place to start on any vehicle.
Old Jul 23, 2009 | 03:12 PM
95slvrZ28's Avatar
I would recommend K&N or Moroso. The SLP is going to be more expensive and not get you any more benefit. I also agree with Kal, an upgraded TB isn't going to get you any HP on an otherwise stock motor. On your LT1 you need to be pushing at least 350+ before you'll start to get any real benefit from a bigger TB.
Old Jul 25, 2009 | 12:39 AM
Sean1995's Avatar
ok thanks you guys what are some things I should do to my car chip, programmer, if so what kind?
Old Jul 25, 2009 | 02:15 AM
evilkal's Avatar
Chips are a waste for these cars too... Save up for a tune instead.
Start like I said... Intake then exhaust. Then you can work on gears and headers if you still want more... Don't waste money on things that don't help.
Old Jul 25, 2009 | 10:30 AM
Failed Devices's Avatar
SLP more expensive? The SLP is around $120, and I have seen the K&N intakes as high as $330. The SLP is a fine intake, I have one in mine with their blackwing air filter.
Old Jul 25, 2009 | 10:39 AM
Old Jul 25, 2009 | 02:15 PM
95slvrZ28's Avatar
The SLP intake retails for $279.95, the K&N retails for $242.95 and you can get the Moroso for $198.95 from Summit. Obviously if you're looking on ebay for used equipment prices can vary, but the SLP has the highest retail price.
Old Jul 27, 2009 | 07:55 PM
You mean this SLP intake retails for $270? http://www.lmperformance.com/741/13.html
That is the one I have, $120 for it, works well.
Old Jul 28, 2009 | 11:38 AM
02StanGT's Avatar
failed devices... did you even read what year the OP has? totally different intake.
