LS Series Tech 1998-2002
catback question
Old Sep 13, 2006 | 10:52 PM
davidalvarez82@hotma's Avatar
Default catback question
I have a borla catback system for my 2000 ss and I want to know if it would be better if I changed the tubing that go's over the rear axle to a straight pipe that go's straight to the muffler will I get a little more hp,mileage or better sound thanks.
Old Oct 5, 2006 | 12:49 AM
Default RE: catback question
Unless you plan to dump the exhaust out ahead of the rear wheels, you will need a pipe bent to go over the top of the rear axle. Can't see how to get to the muffler with a straight pipe without hitting the axle.
Old Oct 5, 2006 | 09:58 PM
JD1969's Avatar
That should be a 3 inch pipe and there would be no gain by going to a straight pipe under the axel (not that you would notice anyways). I have seen true dual systems that go under the rear axel but they are 2.5 tubes and will compromise ground clearance. I think it's cool that you want to improve the performance of your car but I have a feeling your going about it the wrong way. Do a google search for "LS1 free mods" and you see some stuff that is free (or almost free) that has been proven to give you about 8-10 rwhp.
Old Oct 6, 2006 | 04:20 PM
You hit the nail on the head, JD. I didn't even consider running the pipes under the axle, because of the reason you stated. Pipes under the axle over a bumpy road make a very poor combination.
Old Oct 6, 2006 | 08:33 PM
thanks guys for the response's
sebi1990
Feb 21, 2011 08:14 AM
GUHN
May 10, 2010 11:30 PM
Kevinz2895
Dec 20, 2008 06:57 PM
Spartan66
Feb 5, 2008 01:54 AM
HEAVYCHEVYMAYNE.
Aug 31, 2007 11:52 AM
