LS Series Tech 1998-2002
Camaro programer
Old Feb 15, 2010 | 10:44 PM
golieguy3000's Avatar
Default Camaro programer
Hi I was told by a neighbor who is also a autos teacher and big on muscle cars and performance to buy a programmer to get some extra power out of my LS1 camaro. I looked and there seem to be 3 common brand The SLP Performance one, Hypertech and Flashchips. I am wondering if anyone has an opinion on what i should get.
Thanks
Old Feb 15, 2010 | 11:38 PM
Carl Dan's Avatar
i have a hypertech it works pretty well can scan diag codes but only gives you the number not a description of the code, can remove rev limiter, top speed limiter, tire size... and so on.
Old Feb 16, 2010 | 09:15 PM
Have you seen any significant power increase from it, or gas mileage increase?????
Old Feb 16, 2010 | 09:20 PM
Boosted8vfury's Avatar
I dont like my title
your not gonna see much power increase or milage at that rate if it was a disel then yes.... but since its gas maybe 15hp and a few extra mpg but scaning codes is a +rev limiter change is a+and topspeed cut out is a def+ ik my maro the one time i wanted to see what it would do cut off at 117 i was sad!
Old Feb 16, 2010 | 10:10 PM
Carl Dan's Avatar
well power increase is so so... and gas mileage increase def not i have had an issue with my car since i bought it about the end of november dealer had to replace both cat's and all o2 sensors. i have been advised i may need to change my plugs thy may be fouled now. but my gas mileage is aprox 13.45 mpg or so.
Old Feb 19, 2010 | 03:34 PM
Zoilus's Avatar
April 2009 ROTM
Nothing beats just getting a software program like "LS1 Edit" and the the cable to connect laptop to computer and do it yourself or download pre-set Edit codes and install them. this gives you ALOT more options and control but is more complex. some of the programmers only work for stock type settings or if you added a CAI . If you've done headers full bolt ons...etc you may not benefit as much.
92 CaMaRo RS
Oct 2, 2009 07:25 PM
caleb_720_chevysrock
Jul 15, 2009 05:51 PM
markanthonySS
Aug 12, 2008 02:22 PM
markanthonySS
Jul 28, 2008 10:11 PM
jml317
82-92 V8 Tech
Dec 12, 2007 07:48 AM
