LS Series Tech 1998-2002
Average Oil Pressure
Old Jan 20, 2007 | 01:37 AM
98LS1Camaro302's Avatar
Default Average Oil Pressure
Im getting ready to buy my first "american muscle" car. A 1998 Camaro Z28 w/ the LS1.
My main concern is that the oil pressure is good.
The car has 115,XXX miles on it. The oil pressure while at idle, warm or cold is around the 1/4 mark. After you give it gas or drive it it shoots rite up to around 40-55. Is the typically where they all are?
Also, can any damage be done from the exhaust being cut off rite in front of the catalytic convertor? (besides sound like A$$)The previous owner did this because the pipes got messed up when it was towed.
Old Jan 20, 2007 | 01:13 PM
Default RE: Average Oil Pressure
The oil pressure is typical of most cars, low at idle and increases as the revs pick up. You should get the exhaust fixed, if nothing else to keep from asphixiating yourself.
Old Jan 26, 2007 | 12:42 PM
xXxSLPZ28xXx's Avatar
my pressure starts at 1/2 and rises to a lil above 3/4 when i accel
Old Jan 26, 2007 | 02:06 PM
A lot depends on the viscosity of the oil you use.
iTylerSprague
Aug 18, 2011 08:38 PM
morbid
LS Series Tech
Apr 24, 2006 03:01 AM
edgarrison3
Nov 15, 2005 02:34 PM
