LS Series Tech 1998-2002
air temp chip
Old Aug 20, 2007 | 08:50 PM
aap94z's Avatar
Default air temp chip
does any one know what size resistor u can put in line on a ls1 intake air temp sensor. to make it believe it is running at optimal air temp?
Old Aug 20, 2007 | 08:56 PM
Default RE: air temp chip
What temp are you looking for, and what are you trying to accomplish?
Old Aug 21, 2007 | 09:40 AM
SpecterGT260's Avatar
Ninja Administrator
Its right up there with the turbonator......
new craze is to add a resistor to make the computer think its running,not at optimal, but at very cold temps, the idea being that it will dump fuel. more fuel= more power right?
no......
you will run rich and fall on your face. even tho narrowband O2s suck, let them do their job. the resistor trick does not work.
Old Aug 21, 2007 | 09:46 AM
More fuel = more smoke. LOL
Old Aug 23, 2007 | 07:57 PM
aap94z's Avatar
well it helped on my lt1 im tryin to help a friend with his ls1 so i was just askin for a little help
Old Aug 23, 2007 | 08:10 PM
Ninja Administrator
I highly doubt it.u might think it did, but u may find urself smoked by a stock lt1 now [>:]. The REAL air temp is the optimal air temp, because thats what the engine is sniffing. if it thinks its elsewhere it wont perform right.
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
CoyotesLaugh
Nov 19, 2010 11:42 AM
duke15
Jun 20, 2008 10:11 PM
91 RS
Feb 2, 2007 01:56 AM
355CAMARORS
Oct 7, 2006 10:28 PM
