LS Series Tech 1998-2002
01 camaro problems! help
Old 11-01-2011, 09:36 AM
01ssls1's Avatar
Ya it showed both downstream, and everything on this car is original with 92k
Old 11-01-2011, 01:54 PM
shawnathan's Avatar
It might be your sensors but I highly doubt both would go out at once
Old 11-01-2011, 01:55 PM
shawnathan's Avatar
What did you use to clean the mass air flow?
Old 11-02-2011, 10:30 PM
01ssls1's Avatar
Mass air flow sensor cleaner by crc
Old 11-03-2011, 09:26 AM
shawnathan's Avatar
Try taking your neg battery terminal off (leave it off for like 10mins) to clear the codes and any adjustments stored on you kam and then take it for a drive see if the codes come back.
Old 11-03-2011, 09:59 PM
shawnathan's Avatar
Also did you make sure your gaps were set correctly?
Old 11-04-2011, 12:53 PM
01ssls1's Avatar
Ya they are gapped at 60 and I already unhooked the cable and tried clearing them with a code reader. They come back on in two days
Old 11-04-2011, 06:14 PM
shawnathan's Avatar
Does it run bad when the light isn't on?
Old 11-05-2011, 06:28 PM
01ssls1's Avatar
Its runs the same
  #20
Old 11-05-2011, 10:22 PM
shawnathan's Avatar
I couldn't tell you what's wrong without doing actual tests with an Ocicilliscope(sp) to watch what your sensors.
zblad
05-09-2010 02:19 AM
smithdjr
10-11-2007 09:46 AM
NFG687
03-05-2007 07:20 PM
73maro
03-01-2006 03:27 PM
hunterd557
02-17-2005 09:24 AM
Quick Reply: 01 camaro problems! help
