V6 camaro LT's or MT headers?
I have a camaro 2000 V6 and Should i buy long tube headers or midtube. ABOUT how much more HP am a looking at with LT's. How much better is the sound compared to MT headers ? Thanx in advance
With the V6 you're very limited in your selection of headers, to my knowledge only Pacesetter makes headers for you, so you're stuck with their headers, and I believe they are shorties.
Well if they can make them, obviously they'll cost more than mid-tubes because more work goes into them. On the other hand, a header with longer tubes will typically get you more torque in the midrange. They won't necessarily get you more power than a mid tube or a shorty because they all flow pretty much the same, but you do have the advantage that you can get a good collector on a long tube that you typically can't on a shorty. If you can get long tubes, go for it man.
From what I've heard over and over again, with the V6, headers&exhaust will really only change the sound, you're not looking at a lot of power change, it'll bump the numbers up a bit and give you better flow, but no drastic power change -.-
this is what I was told anyways.![EEK!](https://camaroforums.com/forum/images/smilies/eek.gif)
I haven't changed mine yet... but if it works out for ya, let me know.
